| Type de Véhicule | Module | Lecture Calculateur | Lecture des Codes Défauts | Effacement des Codes Défauts | Lecture des Données en Temps Réel |
| 1304 DS 1.9D | Injection diesel | ● | ● | ● | ● |
| 1304 DS 1.9D | Antidémarrage du moteur | ● | ● | ● | ● |
| 1304 DS 1.9D | Unité d'interconnexion | ● | ● | ● | ● |
| 1304 PK 1.9D | Injection diesel | ● | ● | ● | ● |
| 1304 PK 1.9D | Antidémarrage du moteur | ● | ● | ● | ● |
| 1304 PK 1.9D | Unité d'interconnexion | ● | ● | ● | ● |
| 1305 DS 1.9D | Injection diesel | ● | ● | ● | ● |
| 1305 DS 1.9D | Antidémarrage du moteur | ● | ● | ● | ● |
| 1305 DS 1.9D | Unité d'interconnexion | ● | ● | ● | ● |
| 1305 PK 1.9D | Injection diesel | ● | ● | ● | ● |
| 1305 PK 1.9D | Antidémarrage du moteur | ● | ● | ● | ● |
| 1305 PK 1.9D | Unité d'interconnexion | ● | ● | ● | ● |
| D.CAB1.9D | Injection diesel | ● | ● | ● | ● |
| D.CAB1.9D | Antidémarrage du moteur | ● | ● | ● | ● |
| D.CAB1.9D | Unité d'interconnexion | ● | ● | ● | ● |
| DUSTER | Injection | ● | ● | ● | ● |
| DUSTER | Module de contrôle de la transmission | ● | ● | ● | ● |
| DUSTER | ABS | ● | ● | ● | ● |
| DUSTER | UCH | ● | ● | ● | ● |
| DUSTER | 4 roues motrices | ● | ● | ● | ● |
| DUSTER | Variable P.A.S | ● | ● | ● | ● |
| DUSTER | Traceur | ● | ● | ● | ● |
| LOGAN | Injection | ● | ● | ● | ● |
| LOGAN | Module de contrôle de la transmission | ● | ● | ● | ● |
| LOGAN | ABS | ● | ● | ● | ● |
| LOGAN | Airbag/Prétentionneurs | ● | ● | ● | ● |
| LOGAN | UCH | ● | ● | ● | ● |
| LOGAN | Variable P.A.S | ● | ● | ● | ● |
| SANDERO | Injection | ● | ● | ● | ● |
| SANDERO | Module de contrôle de la transmission | ● | ● | ● | ● |
| SANDERO | ABS | ● | ● | ● | ● |
| SANDERO | Airbag/Prétentionneurs | ● | ● | ● | ● |
| SANDERO | UCH | ● | ● | ● | ● |
| SOLENZA | Injection d'essence | ● | ● | ● | ● |
| SOLENZA | Airbag/Prétentionneurs | ● | ● | ● | ● |
| SOLENZA | Antidémarrage du moteur | ● | ● | ● | ● |
| SOLENZA | Injection diesel | ● | ● | ● | ● |
| SOLENZA | Unité d'interconnexion | ● | ● | ● | ● |
| SUPERNOVA | Injection d'essence | ● | ● | ● | ● |
| SUPERNOVA | Antidémarrage du moteur | ● | ● | ● | ● |
| SUPERNOVA | Unité d'interconnexion | ● | ● | ● | ● |
